Finally got them sounding the way I like them. The ODAC has helped somewhat. Previously I did prefer the HD-580 by far (stock cable only
). The reason is just due to limiting the air getting to the driver.
Honestly the only thing holding back the HD-600 for me is it's bass. Slightly too much for my preferences, but I'm sure it's fine for 90% of people. IMO it sounds like slightly more than neutral, but pretty close.
I put a small square of adhesive Creatology foam on the back of the driver but ONLY covering the round part. The driver still gets air and it doesn't magically blow up.
I don't know how that crappy (rear) foam removal mod got popular. It kills the sound (IMO) and this one is about 100x better and nobody ever tried it. The HD-600 seems designed like a closed headphone. Pretty weird.
The upper/mid bass is reduced a little (not a lot at all) and they're not much clearer and more detailed. I don't know why this would make them change so dramatically. They're now less forgiving of bad recordings.
It seems like previously it seemed to smooth over a lot of my bad recordings and make it easier on the ears. Not sure how it did this. To me this "veil" nonsense is caused by the bass and doesn't always appear.
The HD-580 doesn't seem to have this issue.
Right now it's similar to the HD-580, but even clearer than that and with a similar amount of bass, but a larger soundstage. Something has my ears fooled, but that's what i'm hearing.
Now the modded HD-600 is probably the flattest headphone i've heard. I prefer the Q701 sound, but now it's a closer match and a comparison needs to be done.
I'd love for someone else to use the exact same foam I did and measure it. Maybe I can send in a pair to Tyll or something. I can understand people not wanting to try this due to risk.
It's actually stupid easy to do and takes me 1 minute.
Remove cable, headband and grills. The adhesive foam is the same type used on the HD-800 Anax mod. Creatology foam. Costs $2 at Michael's.
BTW to reduce the stickyness you can press it against your fingers a few times. It's not that sticky to begin with. DO NOT remove the foam already in place.
Such a simple mod and seems to improve the HD-600 more than even all those Grado and DJ100 mods i've done in the past.
BTW I wonder if the HD-650's driver gets more air than the HD-600. I bet it does!
