gEEkzz
- Oct 10, 2004
I don't think so.
Replacing the headband completely might do the trick?
I don't think so.
In a world of objectivists and subjectivists, you might say that I'm an audio minimalist--that is, I like to get the best sound I can for the least money possible, using the smallest number of actual components to get it. That's why I like the HD600 so much--it sounds great to me for everything I play through it, and I don't need some exotic, super expensive equipment to get that sound.
It's a sound way to approach audio, though I've given up trying to be a moderating influence on people on Head-Fi; people will do as they do, and trying to convince them otherwise when they don't want to be convinced is fairly pointless.
I totally agree that the HD600 and some other headphones in this price class are a great middle ground, not too expensive, good sound quality. Improvements in sound quality from this point on tend to rise exponentially in price, though the actual sound quality may only rise incrementally, and will often just slide sideways (different sound signature, for instance).
Personally, I went a step further than the HD600 (well into the land of diminishing returns) and got a HD800, though I still feel I would've been happy with a HD600 as well. I don't buy multiple headphones, though, I carefully pick one, and then just stick with it. I've tried separate amping as well, but to my ears that seems mostly for flavour, and doesn't really add to the sound quality much, if anything.
Just out of interest. "Separate amount" are you running them straight from a laptop?
Actually, the label is a part of what I believe is called a gimbal.
But I only want to replace the label.
E-mail Sennheiser and ask, but you may not be able to do so. The labels may be sprayed on during manufacturing. Are you sure it is a sticker and not paint?
Definitely not sticker.
I am impressed with the Valhalla 2. One word that comes to mind when thinking about the Valhalla 2 with the HD600 is effortless. @Argyris definition of perfection comes to mind: I dont think i could take away anything from this pairing, and hell, cant even think of something I would add.
Buuut... I did some switching between the Valhalla 2 and the Magni 2 uber and the difference was not huge. Probably tighter bass and definitely smoother, less fatiguing sound with, interestingly, more detail in the highs (i love cymbals!). I only compared one part of a song because I had to come to work, but, we will see. Now I am wondering if my initial feelings were confirmation bias, because I really had to try.
I left the Valhalla 2 on, because someone said the tubes need burn in.
Really enjoying the HD 600, but comfort is the worst of any headphone I own, and may be the worst of any headphone I have owned. Too much clamping force and the pads are not particularly comfortable. It isn't terrible, but I have to adjust these frequently and I couldn't see being able to wear these for more than an hour at a time. In that sense I'm disappointed, but I suspect the comfort can be improved, and or I'll become more used to the clamping pressure.
When you do comparison, make sure V2 has been turned on for at least 20 minutes. I don't have Magni 2, but from what I have, I think the difference is mainly soundstage. OTLs have larger soundstage.
