Oops, lol too. Now I see what you're referring to.I have the ivory 598; and like Girgle Mirt, both cups look like the bottom picture, they don't have that ring sticking out., like the top picture.
Could it be light reflection ? I can see the ring outline as your first photo if tilt to the light source, but when i touch, it is in one piece.
So figured out what it is! Both of them have that same plastic piece outline underneath the fabric, except the left cup the plastic ring outline is warped so it's pressing up higher against the actual fabric causing a noticeable outline compared to the right cup. I can press it down to make it look normal and it makes squeaky sounds, right cup perfectly flat so the that outline is barely there. Going to return it & just buy a new one (with warranty). Thanks guys.
