Sennheiser Amperior Impressions Thread
post-9793144
Post #361 of 1,051
Townyj
I missed out on the $150AUD deal, picked them up for $250 later. Even at $250 these are a steal, ive had alot of headphones in the past and these are amazing.
post-9793628
Post #362 of 1,051
a_recording
Member of the Trade: Lachlanlikesathing
Yeah, even at $250. JB?
post-9794175
Post #364 of 1,051
moriez
da sweet spOt
da sweet spOt
Curiosity got the best of me so had to get the Amperior next to my long time baby HD25. I'm starting to find the Amperior's to be quite the improvement! They're obviously a bit heavier but at the same time somewhat more comfortable with that new earpad material and less clamping force when comparing the two. I swapped the improved but still flimsical stock cable for a HD 650 cable and I think that took away a little harshness to the highs. I never thought I'd use an audiophile term but the Amperior is clearly better at instrument seperation which is so nice to be able to hear and notice. They also sound more upfront and bass seems to go a bit deeper.
There's one but. Now that I unscrewed the cable attachment on the cup there's no cover anymore. Looks a bit crappy. Did anyone find a nice solution to that?
post-9796261
Post #365 of 1,051
LAmitchell
Hey there Moriaz,
I too swapped the stock cable for an HD650 cable.... at first it was fun hearing the differences that you describes.
Later on I missed the details that the stock offered so I put it back on....   who knows, I'll probably keep switching the two until my head explodes lol
by the way, I find that doing the spring readjustment that I learned from MADMAX is important when going back to the stock cable....
Here's my quick how to link on youtube.... don't be intimated, it's easy to adjust those springs and so rewarding in that DYI-type-of-way :)
http://youtu.be/WRXYgfIkX18
post-9797473
Post #366 of 1,051
329161
Just got a pair of these at $200 AUD. I'm chuffed. I've just found my fave set of cans. The sound signature is just what I am after. Forward and slamming. The bass punches well, and the treble isn't too laid back. Suits electronica really well. Way better than the HD25 btw (which were overly warm for me).
post-9797730
Post #367 of 1,051
JeckyllAndHyde
there are many very cheap offers right now on ePay - can someone confirm, that these are genuine? refurbished is fine for me :)
post-9797890
Post #368 of 1,051
yeehc0729
By very cheap you mean how much? I saw them brand new $195 sell by razerdog.
post-9798970
Post #369 of 1,051
djkgb
This video opened my eyes on how a more rigid earcup can make a difference in regards to the hd25.
I wonder if anyone at sennheiser got the idea from this video for the amperior, and now the hd25 aluminum.
http://www.youtube.com/watch?v=uHkb4bhdnRA
post-9799250
Post #370 of 1,051
moriez
da sweet spOt
da sweet spOt
Thanks LAmitchell for the advice. Might come in handy but I don't see myself going back to the stock cable soon.
I have to agree. The HD 25 is awesome but when comparing the two I notice some muddyness to it's sound. The Amperior just seems to do a lot if not everything a little but clearly better. A definite step up.
post-9799951
Post #371 of 1,051
JeckyllAndHyde
post-9811526
Post #372 of 1,051
Vemon
I connect my amperior headphone with Headstage arrow amp and switch to high Gain 19dB and high impedance 65 ohm. While playing the music, the headphone are shaking I immediatly switch back to low gain. I want to know if high gain and impedance from amp will damage the headphone in this case?
post-9811588
Post #373 of 1,051
bixby
The Amperior is a really efficient headphone and does not need high gain to get to very loud levels in most setups.  A gain of 19 is way overkill unless your source is really low in output.  Can you set it to something a bit less like 5 or 9?  And not sure what other impedance setting you have but 65 should be okay if that is all you have that is close to the Amperiors impedance.
As for damaging the headphone, sure it could be damaged from cranking it up with that much gain.  Your volume control setting is probably way lower than half and not in the optimum area either with the high gain setting.  Use low gain and turn the volume control up for best results.
post-9811787
Post #374 of 1,051
Vemon
My source is ipod classic 160gb with LOD to the headstage arrow 3g which is a portable amp that I used for my shure se535 and Triple 10 remold 4 drivers. I just want testing the sound quality of amperior with the new amp. The weird thing is that amperior is more sensitive than the shure se535 in high gain. I switched immediately back to low gain after playing few sec with high gain with my amperior. I did some research on the internet, it seem few sec playing music in high gain wont damage the headphone. Well at least I listened my amperior with my ipod touch 5th after, It seem everything is alright. The Headstage arrow have 4 switches Gain
6dB, 12dB, 19dB, Bass boost 0dB, 9dB, 12dB, Impedance switch 0/20/65 ohm and Crossfeed Off Low High.
One more thing, its possible to use Oyaide HPC-H25 with the amperior? I think you just have to buy the Clamp Set for Sennheiser HD-25 to install these upgrade cable?
post-9811813
Post #375 of 1,051
bixby
As long as the Amperiors sound okay then you should be fine.  I just would not run it with high gain at high volumes.  As for proper matching I would start at gain of 6 and see how it sounds and how far up on the volume control you go.  Also to keep the freq response as close to nominal I would set the amp to 0 impedance.  Setting it to 20 would be good for a 150-300 ohm headphone and 65 would be best for 600 ohm cans.
Not sure about the cable, maybe someone else can chime in.
