kaushama
- Jun 29, 2004
May be they have IE9 in development!
Originally Posted by kaushama /img/forum/go_quote.gif Now Sennheiser should have tuned it to have much less in mid bass, in its lowest bass setting out of box. Since they have included bass tuner, there is no logic in keeping the IEM so bass heavy!!! |
Originally Posted by zardos /img/forum/go_quote.gif To me there is no such bumped mid bass feeling, because I get not enough seal with the stock tips which I prefer. The result is that the bass sounds natural and wonderful airy on lowest setting. To me SE530 has a bit more mid bass than IE8 with stock tips. If I force 100% seal on IE8, then yes, too much mid bass. But I would never force 100% seal on these babies because I really love the open, airy sound of the IE8 with stock tips and cable-over-the-ear wearing. |
Originally Posted by jinx20001 /img/forum/go_quote.gif sorry this is rediculous. everybody tries to get 100% seal. if you dont have a 100% seal then id call that a poor seal and poor isolation and as a result poor sound. correct me if im wrong but your happy using them with a poor seal because it gives you better sound yes?? and dont say you havnt got poor seal because anything other than 100% is poor as iem's Require you to have a perfect seal for optimum sound and fit. |
Originally Posted by djayjp /img/forum/go_quote.gif Most likely Frankfurt because they are German 'phones after all |
Originally Posted by kaushama /img/forum/go_quote.gif It shows another phenomenon too. The treble response it affected by its over-powering bass. I experienced worse highs, when it is used with largest silicon tip pushed into my ear-canal to get best isolation and 100% seal. |
Originally Posted by Spad /img/forum/go_quote.gif Semi-open IEMs? Don't they call those earbuds? |
Originally Posted by PhilS /img/forum/go_quote.gif Yes, indeed, with the wrong tips and/or the wrong placement, the sound can really be off. I have found after further experimentation that for me the Comply tips give too much of a seal and, just as you describe, the bass becomes overwhelming, the whole presentation becomes dark, and you lose the highs. For me, with the medium foams that come with the IE8 (which are not as comfortable as the Complys, but certainly tolerable), the sound is lush and just wonderful to listen to. Great bass, tight and not overpowering, wonderful midrange, and plenty of treble. I really think that one really needs to experiment with the tips and the placement to reach the right sound, and it is quite possible that the ear shape/size of some folks might not allow them to achieve the right sound without purchasing tips from outside sources, modifying tips, etc. As far as the issue of isolation, I don't have a problem with isolation. I've been listening with the Giants/Eagles game turned up pretty loud and can't hear a thing. |
Originally Posted by zardos /img/forum/go_quote.gif Maybe 90% IEM, 10% earbud bastards. Very different from other IEM sound-wise, but also a bit different construction-wise with short and thick nozzles. |
Originally Posted by Spad /img/forum/go_quote.gif Wow, isn't this almost exactly what some complain about concerning the Westone 3? Another less-than-perfect IEM--who would have thought. |
In other words, I think we can still make some judgments about the relative merits of various phones, even though fit is very important and influential. I'm not saying anything about the relative merits of the W3 or IE8, however, as I don't own the W3. This is just a general comment. |
Originally Posted by PhilS /img/forum/go_quote.gif That being said, I think that while fit is going to be a factor with every IEM, judgments can be made about relative merit of particular IEM's based on the relative comfort to the majority of users, the sound quality most users experience, etc. Thus, even though fit is important and sound quality may vary for every IEM based on how it fits a particular user, if a large number of users of a particular IEM find that it is harsh in the upper regions, or the bass sounds bloated, or whatever, that seems to me to be worthy of consideration, notwithstanding that an IEM that is generally acceptable or preferable to most users does not sound right to a particular user based on the fit or other issues. In other words, I think we can still make some judgments about the relative merits of various phones, even though fit is very important and influential. I'm not saying anything about the relative merits of the W3 or IE8, however, as I don't own the W3. This is just a general comment. |
