SE530/535 Acoustic Filter Mod: More SQ improvement than cables? Dampers!
Aug 19, 2019 at 10:32 PM Post #541 of 590
When I removed them from my 535s I used a toothpick and just plucked it out but I had to destroy the fabric on the one I removed which was no problem because was replacing them
Aug 19, 2019 at 11:01 PM Post #545 of 590
Will freezing hurt the dd divers?
I'm thinking that it will. Shrink the metal dampers and get a better grip with the damper tool and just pull it out.
What do you all think??
Thanks
Aug 19, 2019 at 11:28 PM Post #547 of 590
If I can ask, what would you do?
Any ideas would help.
Thanks again
I personally wouldn’t freeze them. Freezing to loosen a mechanical friction fit works best when both surfaces are metal (such as a bearing installed onto a transmission differential or into machined bearing race).
The T800 is acrylic resin, which will likely not shrink with freezing. Also, you risk damaging the fragile BA drivers. I wouldn’t do it.
If the stock tool doesn’t work, you can try a small 2.0mm coarse screw with the point ground off. That’s how I made my DIY damper tool. You can grab the screw with pliers once it’s screwed into the filter.
Here’s my post on the DIY tool:
https://www.head-fi.org/threads/aud...pressions-thread.909718/page-78#post-15114229
Aug 19, 2019 at 11:34 PM Post #548 of 590
Thank you
I will try tomorrow
Aug 20, 2019 at 10:42 AM Post #549 of 590
@Papa253 I'm assuming you want to swap out the brown filters for a new pair, right? I'd also think you wouldn't be removing them if you did not already have a set ready to use but maybe the T800 don't require a damper like the se535? You may just have to bite the bullet on this one and pierce through the damper foam and pull it up and out from the bottom. Good luck!
Aug 20, 2019 at 1:32 PM Post #550 of 590
Help please.
I have the Audiosense T800's and I have brown metal filters/dampers installed and one I just can't seem to remove it.
I have the tool but just can't get a good grip.
Any tips or tricks will be greatly appreciated.
Thanks
Which tool do you have?
Thought about putting it in the freezer to shrink the metal and or even Super Glue.
As @Slater confirmed, this won't work. Super glue could damage the drivers as well.
As far as tips/tricks I've removed and installed filters 3 different ways on my westones.
1. The cleaning tool was able to just get enough grip.
2. A 1/16" drill bit just fit into the damper. Angled so it catches the edge, slight outward pressure while pulling back.
3. Last and best way, was this tool I found off Aliexpress.
https://m.aliexpress.com/item/32898287693.html
Aug 20, 2019 at 3:11 PM Post #551 of 590
I did get the damper out this morning with advance from @Slater
Thanks
The trick that worked for me was to heat up the tool just a bit. This expanded the tool just enough to get a better grip I was able to pull it out almost all the way, then fearful of trying to grip it again with tool mite push back I used some specialty tweezers was able to remove a complete15663286505275224767615146606099.jpg
Aug 20, 2019 at 3:26 PM Post #552 of 590
I have the one in this picture
Thanks
I will get the one you suggested
That etymotic tool didn't work for me. I had it but sold it.
Aug 20, 2019 at 4:08 PM Post #554 of 590
Well that explains it.
Different filter, different tool. Not interchangeable.
Glad you got it sorted, friend :)
