Actually, the ASR measurements and Atomic Bob's agree for the Yggy version 1, linearity is the same. It is for the Yggy 2 where the linearity differs. ASR's measurements looks almost like they are two sets of the Yggy version 1 since the linearity is nearly the same, and something is off with the THD+N, maybe it was an issue with that particular unit.
@amirm has offered to remeasure if someone would loan him a Yggy 2. ASR's THD+N for the Yggy 1 actually agrees pretty well with Atomic Bob's THD+N measurements for the Yggy 2 for the single-ended outputs.
So, before we start attacking people again, saying Schiit is the evilest organization known to humanity or
@amirm is a hack who hates Schiit and HF and the world, can we focus on the measurements? There is a lot of agreement here and some consensus could be achieved if everyone just stopped. with. the. character. attacks. just stop.
Linearity at around -95 dBFS (red line on Atomic Bob's graph):
THD+N vs frequency for single-ended at around -87 dB (purple on ASR graph):
@L0rdGwyn, please read my response to
@Mshenay below.
Excellent to see so many of you coming forward with some very similar responses!
Though I'm ultimately disappointed at
@amirm as many of us are, I called him out on his Bias quite a few times on Reddit, and he of course denied it. An I
was reading from his site, but this latest batch of Schiit Measurements are contorted and presented with a clear malice in mind. Which again I and many others previously called him out on both now and in the past
Non the less thank you
@atomicbob and
@jude
Thank you,
@Mshenay. Speaking of reddit and bias,
@amirm posted the following on reddit, in response to a poster named frizo who suggested
@amirm was cherry-picking by not showing balanced measurements. Among the things
@amirm said in his response:
amirm on reddit said:
...And no, using the most frequent connector on a DAC, i.e. unbalanced RCA is not "cherry picking." Using balanced as Jude did, is...
And this gem:
...The second difference is that they only measured the balanced output. This tells me they tested unbalanced and confirmed my (poor) results so they decided to change the topic to balanced output performance...
But did we only measure the balanced outputs? I'm quite certain
@amirm knew very well that I showed
both unbalanced and balanced measurements for frequency response, THD+N, and linearity -- and that Bob showed far more measurements than that from both outputs (not to mention different inputs).
So why would
@amirm suggest otherwise to the reddit folks? I think it's because he assumes most will take him at his word that we only measured balanced outputs (and most there did believe him) and will not bother to verify for themselves. And I believe he also thinks that many there probably don't understand some of this measurement discussion, and so, again, will take him at his word (again, most did).
No, they need to sort out their own differences as Bob Smith (atomicbob's) measurements nearly mirror mine
That is horrific performance for a DAC in this price range whether you can look at my measurement or atomicbob's. His review came out before mine and unfortunately he papered over the poor measurements with flowery words on how well it did.
I don't think it fair to say Bob's measurements "nearly mirror"
@amirm's for the Yggdrasil 2. Looking at two of the basic measurements (frequency response and THD+N) which he uses to illustrate what he sees as two major problems with the Yggdrasil 2, his measurements are actually not like Bob's or mine. His THD+N plot shows a >20 dB difference at 20 Hz (which I'll revisit in a minute).
Additionally,
@amirm complains of the downward THD+N slope, most of which can obviously be explained by the significantly higher THD+N he's showing in the lower frequencies (versus either measurement from Bob and me). Additionally, it appears to me that he measured THD+N all the way out to 20 kHz and may not have had his analysis bandwidth set wide enough to even include the higher frequency harmonic distortion (the "THD" in THD+N) through that range.
The Yggdrasil 2's noise floor is quite low, so the THD+N measurement will be dominated by THD -- as such, if you don't include the THD going into the higher frequencies (yet you show an X-axis that goes out to 20 kHz), then, yes, it'll downward-slope as you increase frequencies to the point where their harmonics exceed the upper range of the analysis bandwidth. I posted an example of the difference between my THD+N measurement with bandwidth set to 90k (Fig.4, solid line), and then with bandwidth limited to 22.4k (Fig.4, dashed line). You can see that the more bandwidth-limited THD+N reading starts to separate from the other one quite early (<40Hz) as the high-order harmonic frequencies become scarcer as the sweep frequency increases closer to the bandwidth limit.
Look at the THD+N measurements below, make sure to keep in mind that
@amirm and I are measuring from 10 Hz to 20 kHz (though, again, I strongly suspect his measurement bandwidth is set far lower than the 90k I had set), and
@atomicbob is measuring from 20 Hz to 10 kHz. If you look at the level of THD+N at 20 Hz,
@amirm is showing around -61 dB (Fig.1). If you look at
@atomicbob's at 20 Hz, he's showing around -82 dB (Fig.2). If you look at mine at 20 Hz, I'm showing around -82 dB at 20 Hz (fig.3). In other words,
@amirm is showing >20 dB higher THD+N at 20 Hz than the measurements from both Bob and me.
@amirm's THD+N doesn't fall below -80 dB until around 400 Hz, again, accounting for most of the downward slope he's talking about.
Fig.1 @amirm's THD+N measurement, unbalanced output (10 Hz to 20 kHz)
Fig.2 @atomicbob's THD+N measurement, unbalanced output (20 Hz to 20 kHz)
Fig.3 My THD+N measurement, unbalanced output (10 Hz to 20 kHz)
Fig.4 My THD+N measurement, unbalanced output (10 Hz to 20 kHz), with an overlaid plot (dashed lines) showing the same measurement with bandwidth limited to 22.4k (versus 90k with the solid line).
And then there's the frequency response...
Fig.5 @amirm's frequency response measurement, unbalanced output (10 Hz to 20 kHz)
Fig.6 @atomicbob's frequency response measurement, unbalanced output (20 Hz to 20 kHz)
Fig.7 My frequency response measurement, unbalanced output (10 Hz to 20 kHz)
@amirm's unbalanced output frequency response (Fig.5) has an unusual concave sag <300Hz, and a greater overall dip than either mine (Fig.7) or Bob's (Fig.6). Of this, he says:
amirm on Head-Fi said:
The top line is the Gen 2 analog board in balanced mode. All is well there. But if you look at the two curves at the bottom, both of which are for unbalanced output, we see problems. The Gen 1 board has a small roll off < 20 Hz which we could ignore. But Gen 2 board starts to drift down at some 300 Hz and by the time you get to 10 Hz, it is down by half a dB.
And then to assert that this is an audible problem, he continues:
Controlled listening tests by Toole/Olive show that low frequency deviations that are this broad have a threshold of hearing of 0.5 dB. So this is right at threshold of hearing...
Neither Bob nor I showed a frequency response that came close to crossing that threshold within the audioband. Bob even magnified the frequency response measurement to make clearer the deviation from flat, and you can see this below (Fig.8).
Fig.8 @atomicbob's frequency response measurement with magnified Y-axis, unbalanced output (20 Hz to 20 kHz)
While my measurement is not magnified (Fig.7), the the deviation on that measurement is +/- 0.139 dB for the left and +/- 0.136 dB for the right from 10 Hz to 20 kHz. Within the audioband (20 Hz to 20 kHz), that deviation is even smaller at +/- 0.058 db and +/-0.056 dB. So, whether restricted to the audioband -- or even going lower than that to 10 Hz -- the deviation is well below the threshold that
@amirm cited to suggest an audible problem.
So, do Bob's measurements "nearly mirror"
@amirm's? No. Again, this is not at all similar to what either mine or Bob's measurements show. Nevertheless,
@amirm invokes Bob's measurements (in my opinion underhandedly) to suggest Bob's concurrence with his measurements (vis-a-vis mine) when it's convenient to his argument. Why on earth would he do this? Again, I think
@amirm knows the reddit readers will likely take him at his word (most there did), and will not likely check for themselves.
He then goes on to say that measuring the balanced outputs is not necessary (or even represents cherry-picking -- see his quote above) because he says most people use unbalanced outputs. How does he know this about Yggdrasil users? Also, since he posted a frequency response from the balanced outputs of the Yggdrasil 2, the DAC was at one point hooked up that way on his test bench -- why not show the rest?
...Most people use unbalanced output so them testing balanced output makes little sense.
Really?
Even if it was true that most Yggdrasil 2 owners used unbalanced outputs (and not balanced), it made me think of another analogy: Last week a friend took me to an autocross track in a Roush Mustang to do some laps. This Roush Mustang had several different performance settings selectable via a knob. I don't remember the exact mode names, but there was something that was more compliant, Sport, and Track. If you're curious about how fast that car could lap a given track in its more compliant, more tame mode, that's fine. But is that representative of what the car can
really do around the track? If you know there's a performance difference between the settings, simply show both. But to show what it's really capable of, you'd have to at least show Track.
Now, if you choose to only measure this car's track time using the more sedately tuned, more softy-sprung mode because that's all
you care about and that's the only mode
you'll use, and that information is solely for
your personal perusal and consideration, that's fine. However, if you're going to make a post reaching thousands of people, or hundreds of thousands (or even more) to discuss this car's performance level, I think most would agree that at least including the Track-mode lap time would be the fairer approach.
All in all, I'm actually less bothered by
@amirm's measurements than some of the other things he says that I feel are quite deceptive. While his measurements might be explained by a bum Yggdrasil 2 unit (of all people, perhaps Murphy's law would just so happen to put a bum one in
his hands), I believe many of his quoted statements above can not be described as anything but far less than forthcoming.
So, yes,
@Mshenay, I do also have some funny feelings about some of the things I'm seeing here. And as I said before, I'm feeling a sense of
déjà vu with this one.
