Timster
I wouldn't put anything on top of a Vidar.....
Maybe, but under a small load, how hot does it get? I agree if you were running it hard, but smallish room, and efficient speakers it shouldn't be an issue, should it?
Schiit make a pretty good amp that would match, and you can have the Bifrost on top of it..... http://www.schiit.com/products/vidar
(A) Putting anything on top of a Vidar is a bad idea
(B) Vidar: Size: 9” x 13” x 3.875” Bifrost: Size: 9 x 6.75 x 2.25” so the Vidar is easily twice the size of the Bifrost.
So, no, the Vidar isn't the answer to my needs.
I think mine idled at slightly over 50W or so when I measured it, and went closer to 60W when playing music. It does get nicely warm even when idling, but not hot. The only time I have experienced it truly hot was when I took it to an audio store to audition speakers, on a hot day, with lots of other equipment running in the room, and bad ventilation. Still no issue, though.I saw a review that said Vidar idles at about 60 watts, which seems high. Does this sound correct? Schiit's specs and literature don't mention power at idle. Is the case warm at idle?
If you're looking for something of a similar depth to Bifrost you may have to go Class D or similar topology. The only small class AB amp I can think of is the AudioEngine N22, but i think that sits vertical. Other one that comes to mind is the new Exposure XM series, but I'm thinking these might be pretty deep as well, like Vidar.
What is next? Mono block DACs?
$44K Ha Ha Ha Ha Ha!!!
The Select DAC is powered by MSB’s Hybrid DAC technology. A total of sixteen channels across eight modules are stitched together for a high powered direct output. There is no amplification stage needed to drive the output—only a pure digital-to-analog conversion.
Lends new meaning to the phrase, "I'll take two!" but think about the balance control options. And madness for the more OCD of us.That's right, you need two of these preamps for a two channel system.
I'm still trying to find out if money isn't really an object if going Vidar for bookshelf speakers at a computer setup is better than just relying on a Ragnarok. Any thoughts?
