My new Rag 2 has been cooking for a week and a half now. I use this primarily as a speaker amp connected to my Thiel CS 1.5. I believe the reviews that stated the Rag is bass shy are a bit off bass - pardon the pun. Prior to the Rag 2, I had been using a Krell S300i integrated amp. The time came to move on from the Krell. I wanted something with 2 balanced inputs and a headphone out. I had no doubts about the headphone out of the Rag 2 being superlative, but I will admit I was concerned about the output power of the Rag 2 being enough for my Thiels and the reviews that indicated the Rag 2 was a bit bass shy. For the first couple days, well, I was sweating because while I was hearing outstanding detail, the top end was a bit on the bright side and yes, there was a lack of deep bass. I decided I wouldn't get too judgemental as I know the amp needed to cook, so I left a tuner playing full time when I was not listening. At about the one week mark, the sound started to settle in and the low end was filled out much more evenly. Now keep in mind, I have the Just An Amp version, so I cannot comment on the sound of the built in digital board or the phono. I have separate components for those duties. But I find the Ragnarok 2 to have all of the bass I was getting from the Krell I had been using. I think the Krell may have had a very slightly better grip on very low end, but the Rag for sure has all of the bass the Krell had, driving my little Thiels nicely. Also the Thiels have a rather flat 4 ohm impedance, so the amp is not putting out more than 100 watts into the speakers, but it drives them loud enough for me. I am not a head banger, and I did test the amp in low gain at volumes that are higher than I normally listen at, but I had no issues what so ever. The Rag 2 gets two big thumbs up from me. At some point, I will give the headphone out a good listen, but right now, I am enjoying my speakers too much.
