bigro
- Dec 18, 2014
Thank you! Yes that's how I want set it up! Eaither there's a $600 marantz that has only optical in&bout or theres a $1100 that has all 3 inputs&bout (coaxial, optical and usb) would optical audio be the best?
Thank you for your help! And summarizing everything!
Both Optical and Coaxial Are S/PDIF, which stands for Sony/Phillips Digital Interface (Internet Searching is your Friend) but use a different Medium or cable. Optical uses TOSLINK and COAXIAL Uses a well, A coax cable with RCA ends. (A note on this while an RCA cable may work on a coax connection a COAX cable is different that a standard RCA interconnect cable). I'm no Engineer but your output Quality should be the same.
As Far as which cable is better I use both. I like Optical but I work with Fiber all day so I am Biased. But I use COAX on my modi2u and now the Bifrost MB.
If the $600 Marantz Network Player will Output the same as The Coax of the $1100 One. meaning max of say 24/192 . I don't see paying almost double the price for the Coax output unless it had other features that are worth it . Also If you are Talking about the NA8005 ($1100) it Only has Optical and Coax Output.
From Marantz's Website
DIGITAL OUTPUT
Digital Coaxial | 1 |
Digital Optical | 1 |
DIGITAL INPUT
USB (Front) | iPod / iPhone compatible |
USB (Rear) | Input for PC |
OTHER
Need to pay attention to the Input and outputs other wise you will be spending a lot of time trying to make a Circle Fit in a Square Hole
