- May 11, 2009
What tubes are you using in your LD MK6+?
Looking forward to listen to the Mjolnir at the UK Can meet in September and compare it to my LD
Got back from NYC on my 2 weeks time with family. As soon I got home plugged the Mjolnir and let it warm up for like 20 mins. Then some listening with my LCD-2 rev.2 I can easily hear the difference compared to my LD MK6+ and Eximus DP-1. I let it burn for a whole night using the LCD-2. In the morning listened some more and this is my early impression on it.
Compared to the MK6 the Mjolnir is has better detail and better channel separation. It has a slightly less weight to the sound than the MK6.
Tubes come to play here.
The Eximus DP-1 have always been a little underpowered for the LCD-2 imo. Could not make the LCD-2 sing like the Schiit and LD.
But what really impress me the most was how much better it matched with the Yamaha HP-1. I have 2 HP-1, one in stock and another recable to 4pin. I can easily hear how much better the HP1 and Mjolnir is compared to the DP-1 and HP-1. Its like a veil has been lifted. Its like a comparing a stock T50rp to a modded Paradox. Yeap its that good when using a HP-1 and Mjolnir.
Still have a couple more phones to listen with the Schiit but man the Mjolnir and HP-1 sure sounds wonderful. Gonna do some a/b comparison soon with LCD-2 and HP-1 since both are 4 pins and got a dual 3pin to 4 pin converter so I can listen without having to unplug one or the other. Thanks to Steve from Q Audio for the adapter.
