shultzee
Static isn't normal. Doubt if it would be the amp. Try a few different outlets to see if you are picking up noise through your power source. 2 nd , switch back to your stock tubes to see if it is coming from your orange glow tubes (not likely),
3rd make sure it isn't coming from your source dac/server/laptop, and lastly swap some of your cables if possible. Personally I find the mj 2 to be dead silent.
Hm my setup is like this:
Tripp Lite LC1200 > PC > Gustard U12 > ADCOM GDA700 > Mjolnir 2....
I do think it might be the cable I'm using because it does run a bit long at 6 ft and it's just a stock one from my printer because I had lost my other cable. Should I get a somewhat decent Amazon or Monoprice one and see if that helps my case?
You could throw another cheap usb cable at it to see of the problem goes away before buying a pricier one. I had one go bad after using it for year plugging and unplugging from dac to laptop. On another note I did hear a little distortion on a set of tubes before they were run in. It went away after a few hours.
