Gavin C4
Member of the Trade: Hercules Audio
I am also using Mjolnir 2 stock tubes with the HE1000. Low gain is already more than enough for the volume. Never turn it pass 9 oclock on low gain.
Well, they found nothing... So I am going to try a couple more things this weekend and then, send an email to Nick if I can't find anything.Nop, so far, only local Schiit dealer takes care of it. But, if they can't find anything, I will try to contact Nick. Thanks for the advice !
How can you use a prefazor LCD-X ? Aren't they all Fazor ? I thought only the LCD-2 and 3 had some prefazor drivers.I'm patiently waiting for the combo to arrive
I have also returned the HEK for the HEK2, Got 3 pairs of tubes, and got a used pair of Audeze LCD-X
I'm set for the foreseeable future
Ah yeah. I should have been more specific. I also meant other than SchiitLyr? Valhalla? Vali?
Hi Guys,
Is there any other option on the market to the Mjolnir 2? Meaning headphone tubeamp + preout for active speakers...
Many thanks in advance!
The connection between mj2 and gumby multi bit......
Does it have to be a balanced xlr or can it be a regular xlr
The ones I got from monoprice don't say anything about quality or balanced
