Schiit Mjolnir 2 Listening Impressions
Aug 15, 2017 at 1:40 AM Post #2,146 of 6,930
MJ2 continues to be my recommendation as a do-all amp. It's not euphonic in the way that the Woo stuff is, but it is highly neutral and linear, and with good tubes achieves incredible transparency. With *any* tubes it is ridiculously POWERFUL and will make a tremendous headphone amplifier even for HE-6 and K1000.
Aug 15, 2017 at 4:57 AM Post #2,147 of 6,930
Hi, Sad to read of your problem.. As other fellow Schiit travelers have already noted, it sure sounds like the phono jack is the issue. Have you consulted with the Nick at Schiit? He is usually helpful, though brief. He can be reached at tech at schiit dot com....
Nop, so far, only local Schiit dealer takes care of it. But, if they can't find anything, I will try to contact Nick. Thanks for the advice !
Aug 15, 2017 at 5:53 PM Post #2,148 of 6,930
thinking of upgrading from lyr 2
is this a no brainer for my new hifiman he1000s?
are they good with low gain
and should I go telefunken again?
Aug 15, 2017 at 6:01 PM Post #2,149 of 6,930
They're fine with low gain unless you want ear blasting volumes.
This is a very fun thread to post in but the product is so intensely recommendable that 97% of interactions can easily go: "Should I get Mjolnir 2 with headphone X?" "Yeah for the money it's the best option."
Aug 15, 2017 at 6:20 PM Post #2,150 of 6,930
the lyr 2 had a bit of a hard time powering my he1k but it still gave me loud volumes
how could this be as bad or worse
its gotta power them better
Aug 15, 2017 at 6:38 PM Post #2,151 of 6,930
More power than the Lyr2, better bottom and top end from a clarity standpoint.
Whats not to like.
How do I know? I have both.
Up graded when they released it as I had a bunch of good tubes from rolling on the Lyr. Paired with Yggy, it's end game for me.
Well at least for the time being.
If the Ether E's are as good as they appear from the early comments, I could be expanding my HP station.
Aug 15, 2017 at 6:48 PM Post #2,152 of 6,930
I have telefunken e88cc from my lyr 2
and they probably have only 100 hours on them
biggest issue is waiting for mjolnir 2 and gungnir multibit to arrive
Aug 17, 2017 at 11:35 AM Post #2,155 of 6,930
Any impression Elear > Mjolnir 2 with stock tube?
Aug 17, 2017 at 2:46 PM Post #2,157 of 6,930
It's great with the MJ2, but I didn't use the stock tubes. I will add that excellent tubes can be had for a very modest cost.
The Elears are easily driven, the MJ2 will enhance the performance with a very low noise floor and larger soundstage.
Of course, the tubes contribute to the microdynamics within that soundstage.
(Only tried SE with the Elear. I would expect balanced to add dimension.)
Aug 19, 2017 at 3:10 AM Post #2,160 of 6,930
You can do much better than stock tubes :) Go see my thread on Mjolnir tube rolling.
Damn this hobby man!!...I ended up getting Mjolnir 2 it should be arrive sometimes next week, too bad I have to wait Gungnir MB as my local dealer says they're out of stock right now.
I have subscribe to your threads and I hope I can get control of myself to not get lost in tube rolling madness :ksc75smile:
