ThurstonX
Those Telefunkens sound absolutely fantastic and to be just what I am looking for.
Is there any guide on how to swap the tubes? I am a n00b!!!!!
People use different methods. If you're not willing to invest in socket savers (and not really necessary, but convenient if you switch tubes fairly often), then you could try this:
GENTLY rock the tubes back and forth to loosen them in the sockets. That will raise them marginally.
If you can't pull them out directly, you could use a rubber jar opener, rubberized gloves, or tape. Duct tape is pretty sticky, and should pull them out. You can clean off the residue with some strong isopropyl alcohol (I use 99%; 91% should work fine) on a cotton swab, if that kind of thing bothers you.
Yes, you can buy special tools, etc., but they're not really necessary.
