franzdom
- Mar 29, 2006
Do DAC's like Yggy have gain stage also?
I was intrigued by your post and thought that I would try this out. I don't have the HD800 but I do have the HD650. So I connected my Bifrost MB output into the Vali 2 input and then using the V2 preamp out I went into the Jotunheim SE input. Interesting change in sound but I think the sound is cleaner just using the Jot without the Vali 2.
By doing this, you basically have two gain stages. Preamp 1 is adding gain, which feeds Preamp 2, which also has gain. How much gain each adds depend on the knobs.
If these were passive devices, it wouldn't really matter. But active gain stages add noise, so you don't want to do this unless you have a reason to. In this case, there isn't a reason to.
Reasons for stacking gain stages: phono stages (have to boost the mV output of vinyl cartridges to standard 2V used by line stages) and microphones (differences in sensitivity among mics).
I see, thanks for clarifying this for me. I guess that explains why I initially found the sound to be cleaner and more cohesive without the Vali 2 in the chain. However there does seem to be a bit more live-like ambience when the Vali 2 is being used as the preamp. I found that it sounds best with the V2 in low gain and the V2 volume turned somewhere between 1/3 - 1/2 and then using the Jot to set to desired loudness.
It definitely sounds different but I haven't decided if this different is better. It is fun to experiment though.
Tailoring sound to your preferences is fine, but using EQ is a much more effective (and cheaper) way to do it, rather than trying to stack electronic components (unless it's an FX box) to create a certain signature.
There are known parametric EQ bands for manipulating imaging depth, transparency, warmth, detail, "air", etc. This is what recording engineers do.
Does a parametric EQ add noise to the chain? Any model to look for?
Of course, if you're trying to "tube-ify" the Jot for some godawful reason, you'd hook them up the other way around.. but that seems a little daft.
I haven't seen this discussed anywhere. Can you connect an iPhone directly to the Jotunheim's USB DAC using a USB - iPhone cable to play music? In other words, will the phone recognize the Jot as an external audio device when it is connected?
Yes. You'll need the Apple CCK (camera connection kit) and a standard USB host cable. iOS devices recognise the Schiit USB audio interfaces without problems, as a rule.
Basically this?
