Sam Lord
- Nov 17, 2008
Freya is still overkill if you all you care about is passive attenuation, a single source, and don't need a remote.
Remember, passive stages (Freya or otherwise) don't "improve" sound, they just get out of the way. They should have no sound signature, per se.
Yours are good points (as usual), but I have two comments. First, the single source requirement can increase to several at any time, especially in these days of new media types. And the cost of the multi-input flexibility in the Freya is not high: a larger chassis, more relays, and more connectors. Same for remote control, it can suddenly become very handy when the listening space and/or equipment changes.
Second, the buffered output is a big benefit over passive operation. Sure, most users say passive is *very* close to buffered SQ in the Freya, but nobody calls it better. Buffering is a truly ideal way to transmit the output from DACs and other line-level sources. I expect virtually nobody will use passive in the Freya after they've tried the buffered outputs.
