Nice![]()
Looks like you have socket savers in the MJ2???
Correct. Makes tube rolling MUCH easier and keeps the tubes cooler.
Nice![]()
Stay updated on Schiit Audio at their sponsor profile on Head-Fi.
Now I finally got the Gungnir MB but it won't work with my Macbook. My decade-old PC does find it, but whatever I do on my Mac, it won't recognize the Gungnir. The Schiit support says to do an SMC reset and to use an externally powered USB hub, but all that doesn't seem to work. This is the first time I ever had problems with a DAC though. Has anyone else had similar problems and managed to resolve it?
Have you tried both USB ports? My left MBPro port stoppen working with my DAC recently... .
A few preliminary support questions:
1. What playback/media program are you using with your Macbook?
2. When you say that it won't work, is it visible at all in System Preferences > Sound? It should show up as "Speaker-Schiit USB Audio Device".
3. Do you have the proper input selected via the input select button on the front of the unit? Sometimes it gets bumped to one of the other inputs on accident.
What BDM-Fi said could be accurate for you, Puzzles. My "top" USB port doesn't work with USB DACs for whatever reason, but the "bottom" works no issue. I have an older mid-2012 MBP and the one slot stopped recognizing audio devices several months ago. It still recognizes USB memory cards and external drives, so it's not a bad port. Maybe you are having a similar issue.
Pretty sure that Schitt re-programmed the USB card inside the GMB so it can communicate what bit rates it supports to Mac OS. This was something I was wondering myself - does the new GMB still display 24/192 like the old model or does R2R DACs display something completely different? I am a little worried too that something may not work without a driver in Mac OS.
1. Amarra, but it doens't find the GMB either.
2. Nope, it doesn't turn up there.
3. Yes. I've even tried all other modes.
I had lot's of trouble with the GMB during the driver install. (I fix pc's for a living so I do know my way around windows) I have windows 10 on a new custom pc. Downloaded the driver from the Schiit site and I've never had any trouble with any of the Schiit dacs or any dacs for that matter with regard to driver installs.
The first three times the software would call for the dac to be connected but would not recognize when I did. Restarted the pc and tried again. This time the installation completed so I thought I was good. But when I cued up some music with jriver it started and then froze. Had to manually shut the pc down. Then I had to install the driver in compatibility mode and all seems to be working.
This GMB does not get as hot as the original. Can't explain why...
Hopefully you were "just" unlucky" with the installment....But this is the only good thing about living i europe and having to wait longer for the possibility of an upgrade - You guys get to try the GMB first but you also have to deal with the problems....and help find the solutions.
The delta-sigma Gungnir gets quite hot for my taste....so thats good news
