jseymour
- Aug 30, 2016
I forgot to mention that I use Herbie's Tube Dampeners http://herbiesaudiolab.net/tube.htm and they do help.
Well it’s worth a shot !! Thanks .I forgot to mention that I use Herbie's Tube Dampeners http://herbiesaudiolab.net/tube.htm and they do help.
I agree ,thats why I tried three different outlets in three different parts of my house. Problems in all of them. NO problems with the tubes in my Rogue Cronos Magnum.If you’re getting lots of tube noise, especially if you’ve changed around your tubes, I would look elsewhere for the problem. Could be something like a ground fault or noise in your home wiring. I have swapped out a number of tubes and have never had a problem. Tubes have a way of making these kinds of problems more obvious.
Honestly your experience is very different from most peoples. I’m wondering what other components you are using?When I say the Freya is a failure, I mean that in my opinion any audio product that fails to emotionally engage the listener is a failure, regardless of price. It fails as an audio product at a fundamental level.
I left it to burn in over the weekend so I’ll see what happens with an additional 50 hours.
I was hoping the JFET would honestly provide more force/drive — it seems like just an inferior tube mode? The passive mode is just bad.
I had a few problems with a different tube preamp and found the source of noise to be dimmer switches. I ended up having an electrician install a dedicated line to my listening room. Problem went away after that.I agree ,thats why I tries three different outlets in three different parts of my house. Problems in all of them. NO problems with the tubes in my Rogue Cronos Magnum.
I have a dedicated line with PS audio dectet outlets and Ps audio power conditioner.I had a few problems with a different tube preamp and found the source of noise to be dimmer switches. I ended up having an electrician install a dedicated line to my listening room. Problem went away after that.
Certainly, I noticed a pretty bad stridency. I bought the Freya used, so I had hoped burn-in artifacts could be avoided, so we’ll see how it evolves. The high frequency harshness seems to be a much larger issue with some tracks than others though.
I don’t think the lack of musicality is an issue of tuning. I don’t know exactly what the issue is. In terms of detail it easily beats a Mjolnir 2 I was using a preamp. With the NOS tubes I got with the Freya it is also at least the match, and I think a little better than the M2 (Reflektor Silver Shields) in terms of soundstage and imaging. If I had to rely on my gut feelings, I’d say it has something to do with the a lack of dynamic force? I’m not sure, but I notice the lack of emotional engagement in myself when listening, something which was not the case with the M2.
Can a noisy tube bleed into another channel ?
YesHave you tried it without all the PS Audio equipment?
Where did you get the adapters?I recently put Sylvania 7n7's into my Freya, and I'm not looking back.
Tight, well-defined bottom end, mid-range clarity and depth, relaxed highs.
Sylvania 7N7's are also the quietest tubes I have tried so far. All other tubes exhibited the varying levels of 45-60 HZ hum on the “high-gain” Freya.
Regards
