sarang-i
- Dec 12, 2015
My suggestion would be to look in the Eitr thread. I have not read in detail, but there are reported some sensitivity issues due to electrical noise (i.e. in house wiring or due to other things sharing the electrical circuit). I have personally had no issues with either USB Gen 5 (Yggy) or my Eitr plugged into my Bifrost Multibit. I too am using Foobar through Wasapi. So I think you may have to look further upstream for the issue.
Thanks for your reply, actually i was doing eliminate electrical noises, especially handling and testing with multi-tap plug adapters.
When i shaking them, bimby occur multiple clicks.
But clicks never showed up only when i was using USB as inputs(i never use optical input).
I think my bimby's problem is concerned about coaxial input socket, will see after trying some tests tomorrow, 1) eitr+nfb11 to figure out whether eitr is fault or not and 2) belcanto mlink+bimby to figure out whether bimby's coax input was damaged.
