I look forward to every opportunity to listen.
I think Bimby kind of has that effect on us lucky owners
Thanks a lot! Probably won't be getting two of the mimbys, feel like that would be a waste of money. I've gotten advice in the mimby thread to just use a y-splitter or a reversed Schiit Sys, if that won't cause any problems that seems like the best (cost effective) solution.
The Jot dac is probably great, but knowing that the mimby is better... I wouldn't be able to sleep at night Thanks for all great advice, gonna pick up a mimby tomorrow. Doubt my ears are trained enough to hear a difference to the bimby (at least a 350$ one), considering how you guys describe them. Thanks a lot and enjoy your music!
got the mimby yes. Never heard the Jot dac sadly, but the mimby was a big upgrade over my Aune x1s' dac, which is said to be around the same level... well, guess we all hear differently.Did you end up with the Mimby? I run my Elears out of the Jot w/DAC, and it sounds really good to me. Briefly had the Mimby in the mix, but couldn’t tell a significant difference between it and the internal Jot DAC. Sent it back and saved $250.
I've read this as well.You should leave it on all the time. Multibit DACs apparently benefit from operating at thermal equilibrium. Since these chips are intended for dedicated purposes outside of home use, it makes sense.
Plugged the Bimby in, waited a few minutes for the 3 drivers to install and just wow (foobar wasapi push).
You want to use the Event mode in order to utilize the USB Async and let Bimby control the clock.
Windows Mixer and WASAPI has no difference whatsoever to my ears. With WASAPI Event, I just can't watch any YouTube if the sample rate is different from the current file being played on Foobar. I just stick with Windows Mixer which IMO doesn't harm the sound ONLY WITH Windows 10 OS.
Does anyone get experience of randomly clicking of bifrost?
I usually use it with coaxial input and right after changing my ddc singxer f-1 to eitr, whether doing nothing or in middle of music being played by foobar through wasapi, i always got that issue.
Down there is from ratencymon implemented on my pc.
