sludgeogre
- Mar 13, 2014
Search for "Sound" in the control panel. It'll bring up a bunch of tabs, the first one being "Playback." Try the different devices until you get the best results.
Wyred is a USB hub running off a linear regulated PSU, a complete different story from a SMPS powered cheapo hub. It "isolates" the +5V pin of the USB cable but it doesn't provide galvanic isolation.
It was in the Windows App, I had two "devices" from which to make the default. When the incorrect one was selected, I think it's a safe guess because of the noise, also played through the computer speakers occurred. Once I switched to the other Schiit USB Device, all began working beautifully.
My apologies for the extremely low-tech explanation.
Just updating that Schiit is replacing my Wyrd. Kudos to their great customer service.
I wonder what difference it might make...
First time trying to hook up thru the Wyrd my wireless mouse quit working after the initialization but a puter reboot later all was well. No problems with the dac functioning as before so seems to have been a useful addition to the chain. The M/G stack with the USB Gen II/Wyrd and laptop as source is sounding really good.
some occasional pop or glitch when playing music.
My main purpose in getting the Wyrd is to try to eliminate (a) some hi frequency noise coming from the usb when my PC has lot of hard disk activity and (b) some occasional pop or glitch when playing music. Good news is (a) is gone, but (b) does still happen.
On the usability side, my only gripe is that the Geek Out doesn't automatically initialize every time I turn on the Wyrd. To get my Geek Out working I have to unplug/replug it from the Wyrd and then it will initialize and work properly with my PC. Another user of the Geek Out has also experienced the same issue.
I wonder if other DACs face this issue? Or is it just the way the Wyrd works with all DACs?
The Wyrd usually needs to be on before you plug in the DAC, to allow the handshake with the PC.
