In RB'ed Clip+ - EQ setting - Low shelf filter, if I use
cutoff frequency: 100 Hz; Q: 0.7; Gain: +6.0 db
Will the above setting:
1) equally produces a boost of 6 db to all frequencies below 100 Hz (i.e., +6 db at 20 Hz, + 6 db at 60 Hz and + 6 db at 100 Hz); or
2) progressively (unequally) boosts frequencies below 100 Hz, with + 6 db at 20 Hz, + 3 db at 60 Hz and + 0 db at 100 Hz?
I would like to give a progressive bass boost to headphones that sound like ATH-AD900 without affecting frequencies above 100 Hz: http://www.innerfidelity.com/images/AudioTechnicaATHAD900.pdf
I have tried the hardware bass boost of Fiio E17, but don't like it as its bass boost going beyond 300 Hz: http://www.fiio.com.cn/products/index.aspx?ID=100000014895351&MenuID=105026002
Please kindly comment, thank you.
