- Feb 7, 2013
Cool I bought one and rockboxed it, sounds amazing for $35.
Yes it does and it also measures better than most 'audiophile' players.
I just Rockbox'd my Clip + which I'm using with Phonak PFE232 IEMs and my Arrow 4G amp. It seems that the amp hurts the sound and the Clip+ sounds better without it. Is there some settings I should configure on the Clip to help with this? Can anyone suggest some things I should configure to help get the best sound possible with this setup? Thanks!
The Rockbox volume should be set at 0db and then you control volume with the amp.
And as per the discussion with others, how do you feel about using gain? If I don't hear a hiss at the first gain setting, should I use it?
it is recommended to start off with low and only use high if you feel that your 'phones need it.
Recently my old Clip+ died and I just ordered a new one, I will be RBing this one too. I am re-welcome to the club I guess. When I have time, I will also check the thread and read what I have been missing so far
However I see Achmed is Dead is around here, so it must be both fun and informative
