stew1234
- Jul 26, 2008
I currently have my M3 hooked up in a cardboard box. I don't have the volume pot grounded particularly well but there is a significant amount of distortion (I wouldn't really even call it distortion as I'm pretty sure it's from a grounding issue). At extremely low volume there are no problems but when turned up there is very audible noise. I was just wondering if anyone had the same issue when using a cardboard box and if the problem solved itself when you finally put it in a real case.
