stellarelephant
You can also press Home button while you are inserting the usb cable.
What? I've been using the long way every time, until now! Awesome tip. Thanks.
Welp. I just received my X3 and RB'd it right away. It's been "Updating... Don't power off!" for about 5 minutes now. Is it normal or should I start panicking?
I'm pretty sure it only took about 2 mins for me. Hope it goes well for you though.
Hi everyone, i am new in this forum, i have a problem with the rockbox installing, i follow all instructions but i don't know why the system is blocked, the windows offers this message:
xduoo x3 rockbox boot
version d312ba8m-1603
mounting disk...
loading firmware...
error: file not found
i don't know how restored the system, always i have problems to install rockbox, with my ibasso x90 too, at last i can't do it so i have the original system, but in this ibasso i can doing a hard reset and restore the system, in the xduoo nothing, i press the reset but the same, please someone can help me. My english is very bad, i am from Spain. Many thanks, regards
If anyone has a recommended alternative to the X3, let me know.I won't be giving Xduoo or Tomtop any more of my money.
hi, i copied:
Initial setup / Начальная установка:
update-to-rockbox-d312ba8M-160316.zip
rockbox-full-df6898b-160821.zip
in a micro sd 32 gigas in fat32, i had one from my sans clip rockboxed, now understand i forget install the system update, i don't know the process, the same oit happened to me with my ibasso x90, at last could install it but the very unstable, so had to uninstalling it, after of many problems, with the Xduoo at last i back to stock firmware, i have bored in spite of his bad software. the micro sd is in fat32 with the music folders that i had to my sansa...
Fiio x1ii, Shanling m1?
