Perhaps someone has X3 version where it could still change the boot firmware to original and back - so can better check sound differences.
The sound quality of the original firmware is way better than Rockbox can produce.
Hello,
Been a while posting, but I have a new battery coming for my x3. I am wondering to those who have replaced a battery how you did it and what equipment you needed? As much detail appreciated.
Thanks.
Dave.
@Slater, tank you for your response. Do you ae any speifi kit reommendations off Amazon?
Tanks.
Dae.
Not a bad selection of extras in that kit. Personally I'd suggest looking for a similar kit but making sure that its made from S2 steel instead of the chrome vanadium of the cheaper sets. The difference in hardness of the tips is more than enough to justify the cost. Amazon has this in the mid $30s instead of $25 from Gearbest.
https://www.gearbest.com/screwdriver-screwdriver-set/pp_696715.html?wid=1433363
Hey! Bough it the X3 recently and I'm using the stock firmware yet, although I wish to test Rockbox, but now that I heard that it's not working anymore on the dual boot option I got some doubts about flashing it. So far from what I read it about the pros against the stock it's the 24bit over the 16bit thing, but that I don't really care about because my library is all on 16bit.
And I got some questions...
Can someone tell me how does it work the playlists on rockbox? If it's like the stock? Like in the stock version there's this "all songs" function, but from what I saw, this is just for checking the songs files on the SD(IT DOES'T PLAY), Why? Is there something like that on Rockbox, but instead that plays? Because if it has then I'll would be able to play all my songs randomly!!!
Another question. If I click the option button on a Artist folder, would have the option to play all of this particularly Artist songs that are inside? Even if they are organized by "Artist > Album > .flac ? On stock if I click on "Play All", it doesn't play the songs because within the Artist folder there's the Album folder, then the flac. Does Rockbox have this wonderful feature?
And about making playlist, on Rockbox do I have to add music one by one? Or does it have the option to add directly by one click from the Artist or album folder?
The only thing that bothered me on X3 was this.
i wouldn't hurry to change to rockbox from original. I made a mistake and have changed to rockbox an then wasn't able to go back as the last version of Xduoo doesn't let you to go back. That's why i ordered second one and when i will receive it - i will make a comparison for my self personally, as i will be able to check the same songs at the same time from two different firmware, especially in sound quality department. As i want xduoo x3 to be able to decode in 24 bit, and in rockbox it can't do it. Also to sound it as good as it's capable of and not as some rockbox software designer decides. I don't care in rockbox capabilities of sorting and tweaking everything, Only one big plus of it - popper EQ. As original firmware doesn't have any. It could be a problem if you want your earphones sound as you want and not as they were initially tuned. But if it's really rocbox sound quality are worse as some people states, all other rockbox pluses i don't care as much. As the main our goal as a xduoo buyers - best quality sound as possible. You will be able to go to rockbox all the time you will need, but it will be your last step, and after that there will not be any possibility to step back. You could wait for my comparison, before going to rocbox (or not) because i also concerned about the same questions. So in the couple of weeks i will answer to my self (and porhaps to anyone that is interested) and not from the someones opinions.
Rockbox has many features that I do not use but that others love
I'm thinking of organizing my library by Artist > .flac and not by Artist > Album > .flac
