headwhacker
- Sep 4, 2013
Rockbox for DX50 with cwm recovery
Thanks to xzcc for porting Rockbox to DX50
Latest build and install steps from Cholero
Unofficial Installation instruction for Rockbox on iBasso DX50
prerequisites: A DX50 with any stock firmware. If you have an older rockbox installation with CWM (= all before 02/25/2015), follow first the purple reverting instruction below.
There are 2 different ways for the update: choose either brown (microSD fat32) or green (internal storage)
- Download the files:
- Firmware 1.9.4 including the rockbox dualboot app. (older version: 1.9.3)
- the latest rockbox build* from the official page: this is a development build but problems are rare
source code: rockbox git tree - changelog- connect your player to the computer to have access to its storage
- extract the update.img form DX50Firmware...zip to the root of your
a) either microSD card (which has to be formatted to fat32)
b) or internal storage- extract the content of the rockbox-build-zip to the root of the internal storage of your DX50 (it contains one single folder: ".rockbox"). If the file manager asks questions about merging or overwriting because of an older rockbox installation, overwrite all existing files (settings won't be lost)
- Update the Firmware (brown or green, as above):
a) reboot to recovery: Power off the device, then power it on while you are holding vol+then select "apply update from SDcard"
b) Boot the official Frimware and select: Settings / Advanced / System update
-> Firmware 1.9.3 containing the rockbox dualboot app will be flashed (update.img)- that's it, you're done
-> to switch between Mango and rockbox, you have to put the "lock" switch to "locked" position when you are booting then the dualboot selector will appear
Revert CWM to stock recovery (if you had an older rockbox installation)
- download stock recovery
- copy the zip file to the root of the internal drive of your DX50 (or where you usually put cwm-zips)
- Reboot to cwm: Power off the device, then power it on with holding vol+
- Flash stock recovery in cwm:
install zip from sdcard / choose zip from sdcard
* or an optimized custom rockbox build containing these patches "Modern User Interface" ps10, User selectable hold switch mode ps13, "Debounce" patch ps1
can be dowloaded from zippyshare
Theme Installation How-To (Courtesy of Cholero)
1. Download any Theme you like from the official Rockbox page as a packed zip:
http://themes.rockbox.org/index.php?target=cowond2
2. Connect your player to the computer and open the internal memory (usual name: DX50). There should be a folder "rockbox", open it
3. Open the downloaded theme zip file. In the zip file there is a folder named ".rockbox" (yes, with a dot)
4. Open the ".rockbox" folder in your theme-zip and extract all the content to your "rockbox" folder on your player
you're done, now you can select your new theme in Settings -> Theme Settings -> Browse Theme Files
