moriez
Welcome to the club (and a real headphone
) Enjoy!
Did you get the Pandora Hope VI or Sonorous VI version?
Pandora Hope VI, although I believe there is no difference apart from the name.
I bought the Pandora Hope VI last year. It took about 50 hours to break in. I just received the Sonorous VI and it is almost unlistenable out of the box. Hopefully, the Sonorous VI will break in and sound like the Hope VI. Right now the Sonorous VI has harsh highs, sucked out mids and weak bass and mid bass. It is also less sensitive than the Hope VI. Hopefully, the Sonorous will break in and sound the same as the Hope VI. If not, then Final has done something detrimental to the design or construction of the Sonorous VI.
I use the Pandoras on my rockboxed clip+. Do you think it's worth investing in a better DAP or (portable) headphone amp? I mean I already reach a comfortable volume level at -25 dB and the clip has an output impedance below 1. Is there even enough room for improvements to justify up to 400 € for better gear?
No, save your money for something more useful. They Hope VI's are very easy to drive and you are very unlikely to hear a difference using a more expensive amp.
A vs B is vaguely interesting, but seriously, just buy the Shure 1540 pads and be done with it.
They sound as good as the shallow FAD pads and are way more comfortable than any of the other four pad types that I tested.
Appreciate it might not be all that interesting to someone already sitting with 1540 pads. However, the A vs B discussion is helpful if folks want to identify what pads they currently have and how the two differ.
If someone has the type A and is unhappy with how they sound then I can definitely see a case for 'just buying' the 1540 pads as they look like they are a very good alternative to the type B (same or similar sound but w/ > comfort), although I have heard it suggested they may reduce the bass slightly and remove a touch of richness and those are areas I really wouldn't want any compromises. However, if someone already has the type B (flatter pads) then I guess the 1540 pads only become compelling if comfort is a major issue. For me the comfort is fine so no desperate need to replace them, but when the time does eventually come then the 1540 pads will definitely get some serious consideration
I'm a little unclear on which are the a or b pads?
A: Thicker pads?
B: Thinner pads?
edit: Hifiheadphones have low profile and deep profile pads but the photos usefully look identical!
I'm pretty sure I have the thinner pads which results in them being fairly uncomfortable. The hard plastic ridges around the drivers dig into my ears.
I tried my old dt 770 pads which are more comfortable but I don't like what they do to the sound. They are a little soft and well in need of replacing themselves so depending on positioning my ears still graze the plastic a little.
Are the 1540 pads the best for anyone who is having comfort issues? Anyone know where to get them in the UK? They are out of stock on amazon.
