Pricklely Peete
Franken modder
- Feb 17, 2008
Noted boodi.......
Peete.
Peete.
Originally Posted by katanka /img/forum/go_quote.gif anyone ? |
Originally Posted by Trapper32 /img/forum/go_quote.gif The 49710 is a single so you'll need 2 on an adapter....Why not get the 49720 which is the same opamp in a dual format so you'll only need one with no adapter.... |
Originally Posted by Enthusia /img/forum/go_quote.gif Anybody else getting the problem while using the headphone amp of the Zero with the sound coming from the right side louder than the left but then as you turn the volume up more the sound balances out? |
Originally Posted by Pricklely Peete /img/forum/go_quote.gif Do you have the stock volume pot E ? That's a drawback to a cheap one...the Alps upgrade pot is better balanced...it doesn't matter to me since I don't use H/Amp all that often.....one note...the imbalance should only be noticeable at the lowest volume settings...if it 's happening at regular listening volumes the pot needs to be changed.... Peete. |
Originally Posted by Pricklely Peete /img/forum/go_quote.gif Excellent page ianp !!!....thanks for the link....like you I'm learning as I go....always learning ....lately I've been really pushing the info curve into my noggin...such that the ole brain sometimes does one of these Peete. |
Originally Posted by Carter54 /img/forum/go_quote.gif I have been Watchin ghte for sale for a while now and i was the Second PM on the last 2 Zero's |
