can yulong u100 drive akg k701 properly?
thx..
thx..
thx..
I'm not sure if the ASIO drivers are working for me. I'm using Windows 7 x64 and foobar2000, and I installed the setup for the ASIO drivers and was able to select them as one of the output options. However, I think it's still going through the kmixer cause I can still hear all the windows sounds and sound from other programs while I'm playing music on foobar. On the Yulong Audio U100 Control Panel,however, it says that ASIO playback is active and it shows the correct sample rate on the stream. From what I gather, somehow Windows is affecting the audio stream through the ASIO driver somehow. I verified my suspicions because I can notice a severe change in audio quality when I change the sample rate of the Yulong from Window's sound controls to "Telephone Quality"
Has anyone else been able to successfully use the ASIO drivers for the Yulong? Normally I would just use WASAPI, but I'm getting a weird static from my audio output after playing a few tracks and I have to plug and unplug the USB input to make the static disappear. This has only happened to me when I'm using WASAPI (exclusive mode).
I got the Yulong Audio U100 recently and it may be too powerful for my iems (returned some fullsized cans that I was going to use).
At 100% Software volume and 100% System(Computer) volume the dial is like this:
- Step 0 barely audible
- Step 1 left side only whisper
- Step 2 left side only little louder
- Step 3 both channels are on and a tad louder than I'm use to listening with
I had turned foobar2K(Software) down to -40db to compensate only to add noise along with it, but when I tried having the software at 100% and taking the system volume to 25% I gain a lot more dial control(maybe 16? steps instead of 3) with no noise!
Would this be fine for auditioning purposes? or should I find some other solution for my iems (westone um3x on the way)
Originally Posted by goodvibes /img/forum/go_quote.gif
Dither may have a component in the noise that you hear at that level. Try significantly less and see if you can hear a dif.
Is it worth it to spend 100 more to get d100 instead? how big is the difference in performance between d100 and u100?
I am especially looking for a good dac section. I am now owning FA-003, but maybe in the future I will get HD650.
Was thinking about buying this DAC for my Beyer DT880's. Would it drive those alright? Also, where's the best place to purchase from if I live in Canada?
thanks
project86, first of all, let me thank you for your reviews! Great work!
I'm thinking about a possible upgrade over my FiiO E7+E9 combo for desktop use. Since I bought the FiiO E10 for portable use, I feel my desktop combo isn't good enough everytime I listen to it now!
So, I'm considering this U100, or maybe also the Matrix Cube, as a possible upgrade. I think the Cube main disadvantage is it's DAC being "just" 16bit/48KHz over USB, instead of the U100 24bit/96KHz. As my music library is mainly FLAC, don't you think this "issue" on the Matrix DAC can turn out as a real limitation for me?
But then again, apart from that USB issue, the Matrix Cube specs seem superior to this U100...
Well, I mostly listen to FLAC, and some 320CBR and VBR MP3 (from my Windows 7 PC and Foobar2000). I also listen a lot to CDs, from my HiFi CD player, and that's why I need an RCA or 3.5mm jack input on the DAC/AMP...
So, soundwise, you think the Cube is superior to the U100?
