R-Audiohead
- Dec 4, 2010
The problem is that this will still resample everything...
Yea, the real advantage to using ASIO (it seems to me at least) is that you won't "double up" on the upsampling process. I am currently running a DSP in foobar [Resampler (SoX)] to upsample the output to 88.2kHz (just to be nice on this little netbook I'm using until I gain access to my desktop that can handle it - will run optical then) and to my understanding, since I have the Yulong Audio Device set to 24/96 in the control panel this 88.2kHz upsample product from foobar will AGAIN be resampled to 96kHz.
Maybe I'm wrong, but it seems like converting twice could have some negative effects, but the question is whether or not converting straight to 96kHz in foobar bypasses the win7 conversion or not. Even then, is the upsampler I am using effective at 96kHz or more accurate at 88.2kHz? If so, it might be worth it to use ASIO to bypass the win7 conversion all together, and just run ASIO with the foobar DSP.
Maybe I don't understand this correctly?
