davidvanderbilt
- Mar 25, 2010
Has anyone compared this to the Schiit Bifrost? I'm trying to decide between the two
anyone compare the D100 with AudioGD NFB-12? Or if anyone can tell me if upgrading to the D100 will be a significant change over the
NFB-12.
Are the balanced XLR outputs line level? or can they be volume controlled (essentially, could you use this as a balanced HP amp)
Essentially, it sounds like this is a step up neutrality and sq wise from the Matrix mini-i (albeit more expensive)... but I'm wondering if it can function as a poor man's Audio GD NFB-10SE.
When I use S/PDIF the display is showing 48KHZ, however it was 96KHZ when I used USB. Is it because S/PDIF is limited to 48K? In terms of quality should I go back to USB? I am using a lenovo laptop.
I have set upsampling to 192k in foobar, but I don't see any similar settings for Windows 7.
