- Apr 28, 2010
-disregard, posted in the wrong thread!-
Hey guys maybe some of you can help me out. I plan on getting some KRK RP6G2 Rokit G2 ( http://www.amazon.com/KRK-RP6G2-Powered-Monitor-Speaker/dp/B001A6IC7Q ) monitors and hooking it up to my Yulong D100. I really have no idea what I'm doing I'm guessing 3 pin xlr male to female ? Or do I go rca preamp to the KRK from my Schiit Lyr? Like I said this is my first time using a dac with something other than headphones so I really have no idea what I'm doing. Can anyone help me with the best way to connect this set up, and which plugs exactly do I need? Thanks
John
John
Connect two of these (one for each side): http://www.amazon.com/GSI-Premium-Female-3-Pin-Cable/dp/B0058UXBYO/ref=sr_1_10?s=musical-instruments&ie=UTF8&qid=1313626526&sr=1-10
to the TC Electronic Level Pilot female inputs (http://www.amazon.com/TC-Electronic-Level-Pilot-Computer-Independent/dp/B001PGMNRG).
Connect the male with the pins sticking out cables from the TC Level Pilot to the XLR input on the back of each of the monitors.
Turn the TC Level Pilot knob to max, and turn up the knobs on each of the monitors to the maximum volume you will need (make them as balanced with each other as possible). Leave the back knobs alone now. Use the TC Level Pilot ot turn the volume down to what you want, and turn it up, and now when you turn it all the way up it won't go much louder than you need to use.
I don't own this knob, but people say it is transparent and doesn't affect sound quality at all. Also, I don't know exactly how far it goes, like some knobs just turn forever both ways with no maximum or minimum. If it goes forever, just ignore the part where I say turn it to max and turn the knobs on the backs of the monitors halfway or so and use the TC Pilot knob for volume up and down. Now you don't have to balance it all the time and get behind the monitors!
If neither of these setups are working, or you need more help, PM me.
P.S. The XR cables I linked on Amazon are 5 feet long, and the TC Level Pilot input and output cords are all 6 feet long. There are longer cables than the one I linked in the first link (not the knob). There are some exactly the same but 10 and 15 feet long, just search for them. Also, if you want the knob closer to you and farther away from the monitors, get a third cable of the kind I mentioned and connect the female end with the holes to the cord on the TC knob with the pins sticking out and the male with pins sticking out into the back of the monitors.
Again, if you need more help, PM me.
Can you explain why I would need this "Level Pilot"? Why wouldn't I be able to just use xlr 3 pin into the D100?
Ok. The more I ask the more I seem to be getting confused I do apologize. Can anyone explain why this set up to the same exact speakers to a dac with basically the same outputs as the Yulong doesn't involve an additional volume control?
http://www.head-fi.org/t/564898/audioengine-a5-vs-krk-rokit-rp6-g2-nice
