ZapX629
- Dec 28, 2013
Thank for the good answer. I take it as it is a very big difference then? I maybe should buy them then...
I haven't heard the XE800, but I have the GR07, which they're based on, and in comparison to the Pistons you'll get less bass, but infinitely tighter and more articulate bass, bigger soundstage, much better clarity, separation, imaging, etc. The only place the Pistons would be an advantage is if you need a lot of bass boom in your music, but other than that the XE800 should be a few tiers higher in every area.
Yes there's an significant difference in sound quality between the two. If you can get the XE800 for around $60 shipped it's a ridiculous good value. If you're considering paying $100 for them they're still worth it but you might want to consider GR07 for $80 from lmue as an alternative.....
Yeah, if you're paying more than $80, I'd just jump on LMUE's sale that's this weekend only.
