rangga
- Jun 28, 2013
i've tried the V800 and V200 stack combo at Mike's Headfonia Store a couple days ago. With Hifiman HE-6, the voice of Diana Krall is just awesome. So effortless, with good ambience.
Really liking my v200/v800 stack
Thinking about getting upgraded power cords and interconnections, any Recommendations?I know it has been discuss somewhere here but too many pages back
Just fine running at this stage. Thanks in advance.
Lake People/Violectric would tell you that you don't need fancy cables. Some here would agree, some wouldn't. Personally I think if you get the itch to upgrade, try cables from a smaller manufacturer who doesn't build marketing costs into every cable they sell. And try to find one with some type of in-home trial period where they can be returned if you dislike them.
I use Cabledyne stuff for AC and interconnects. They satisfy both criteria. But of course there are many options.
Speaking of USB inputs..I'm getting V800 soon and will use USB input.
Did anyone try any of tinygreen PC solutions, like FitPC2?
I have a PC but it is very noisy. A fanlsess/silent setup is the best; something that runs windows > Foobar2000 kernel > usb > v800 > v200 > headphones > happy!
Can be easily controlled with android remotely
I researched on SB which is discontinued, C.A.P.S which is costly and way more than needed.
Building custom-built is too much hassle, and buyign pre-built silent PCs are expensive. (~1000$+).
FitPC2 seems like a good match given price, can stream music via LAN/WiFi, it is silent and not bad looking.
