guido
- Jul 3, 2003
I am about to receive a V800 and I am going to use it with my V200 in balanced mode.
I have these XLR cables from TAM audio [the same ones Project86 is using] but I have opened up the connectors and noticed that pin1 on both sides is only connected to the cable shield and not the connector body.
In the V800 manual it states :
[size=10.000000pt]In case of balanced cables, it should always been verified if the shield of the cable is connected to the shell of the XLR connector. The shell is ALWAYS connected to earth potential when the connector is inserted !! [/size]
Should I then connect pin 1 on both sides to the connector shell?
