A huge +1
For me lifting grounds on both the V200/800 and the low pass filter on the V200 volume pot made the most significant improvements sonically....
actually for me the most significant changes are felt while playing with the gain combinations on both the v800 and v200, balanced and single ended,
I was thinking of picking up a v800 on the secondary market, but a lot of them are located in countries that uses 230-220v power.
Since I am in the USA (120v mains) I was wondering if the V800's power supply is able to handle both voltages. Looking at pictures on the Violectric and the USA distributor's website seems to indicate that the v800 can support both. PDF manuals for the v800, however, seem to indicate that there may be 2 different versions depending on mains power.
Can anyone confirm?
Thanks!
two different versions, however if u r confident with reterminating the transformer u could convert either
I guess I assumed it comes to preference and benefits and cost to the mod.
But if it has no down side. I should read up. But kind of scared to touch a $2500 investment.
and there is no in depth instruction on how to open the devices in the manual, i was super careful, and noticed it can be a little tricky for someone who's not accustomed,
first turn off and unplug the power mains cables and all the other cables as well
for the v800 one should first remove the metal cylinder of the volume pot and the nut underneath it, that holds the pot to the case,
than the two hex, upper left and right screws on the front panel
than the four corners hex screws from the back panel
than slide the back panel (the pcb on which it's screwed on comes along) straight out about 5mm
than lift the upper cover starting from the back
for the v200 lift the two hex, upper left and right screws on the front panel
than slide the back panel (the pcb on which it's screwed on comes along) straight out about 5mm (not more cos there's a patch cable holding the pcb to the pot and the front panel)
enjoy messing with all the configurable settings
