Review: Violectric V800 DAC
Feb 16, 2013 at 5:47 AM Post #346 of 828
Sling5s...check out some of the recent posts above...Fried from Violectric stated "Concerning USB 24/192 we are working on a solution and want to be ready for the Hi-End exhibition in May in Munich."...he also talks about current owners perhaps having the opportunity to send in their current V800 for an upgrade.
Surprising, though if this is the unit being advertised on a 3rd party site already??? Interesting.
Feb 17, 2013 at 8:09 AM Post #348 of 828
Sling..I live in the USA...and I found that when I priced the V200 and V800 out around the web that buying directly from Violectric offered me considerable savings, on the units and shipping. Great products!
Feb 17, 2013 at 10:39 AM Post #349 of 828
I should have considered that but my v200 and v800 were from aphroditecu29.  Robert did give me a discount though.
Feb 19, 2013 at 11:22 AM Post #351 of 828
TOS-link between Mac and V800 is always used here. :)
Feb 19, 2013 at 5:07 PM Post #352 of 828
My V800 seems to go to mute when I switch to optical.  USB and Coaxial seems to work fine.  Any ideas?
Feb 19, 2013 at 7:44 PM Post #355 of 828
Not sure if this helps, as mine is a Mac Mini but...Is your optical cable showing light? If not, does your Mac have 'digital out' selected under Settings - Sound, and shows 'optical digital-out port' or similar?
Feb 19, 2013 at 8:44 PM Post #356 of 828
LOL.
It's been so long since I've used the optical out of the iMac that I thought it had a separate optical out.  I guess the headphone jack and optical is one and the same.
thanks for the help.
Feb 19, 2013 at 9:31 PM Post #357 of 828
^ heh heh - the marvels of multi-function technology!
Feb 20, 2013 at 11:59 AM Post #358 of 828
i'm a little confused, i use the v800 (sn v800544) and v200 (sn v200554) together
1. which labeling is correct for the groundlift jumper, in the v800, the one on the pcb inside the v800 or the one as pictured in the v800 manual
   the labeling on the v200 pcb and v200 manual is the same as on the v800 pcb, so my guess is that the labeling pictured in the v800 manual is wrong, mirrored?
2. for groundlift jumper on both device's manuals (v800, v200) gnd is stated as ex works, but on both i found it was set on lift by default, when i first opened the devices, how comes?
3. on the v800, the balanced output level for 0dBFs is set to +15dBu, all switches lowered, for balanced analog xlr outputs, but which actually translates to +6dBu ex works, all switches lowered, for unbalanced analog rca (and unbalanced xlr) outputs?
   so if i want +15dBu gain on rca unbalanced analog outputs i need to only rise the +24dBu switches inside the v800?
Feb 21, 2013 at 8:40 PM Post #360 of 828
well by looking at page 7 of both v200 and v800 manuals i'm confused even more,  by the position of the jumper in respect to the 10k resistor and 100n capacitor on the pcb
EDIT: i took it apart, from the back of the pcb the truth emerged
the lable on  the pcb is correct,
