emptymt
how does the ETHER sounds through this amp?
I will be using chord mojo as dac.
Lake People RS 06. Are you from the US? If yes, then ask Violectric USA for a price.
Else, Schiit Bifrost Multibit.
Thanks. For now I'll be using my NFB-11 DAC but will look into upgrading it later this year/next year.
By the way, just ordered the V200 from Thomann.de for 699€ (B-stock). Super excited right now. Can't wait for it to arrive.
Also, I am a bit confused about the pre-gain options in the amp:
What would be the best settings for the HD-800?
Looking for a decent, fairly inexpensive DAC to go along with the V200 and Sennheiser HD 800 (SuperDupont mod). Would Schiit Bifrost do the job? Any other recommendations in the same price range?
Thanks in advance.
What about the Violectric internal DAC board for the V200?
There is a choice of 7.
Is there any way to connect 4 pin xlr balanced headphones if there is no 4 pin xlr output?
