project86
- Feb 21, 2007
Concero has a lower than normal output voltage. At max volume setting it is something like 1.2Vrms, in order to take full advantage of the particular parts used. So it makes sense that you would need to crank V200 volume up higher than usual. It's no problem as long as you aren't running out before it gets loud enough.
