Review: Violectric HPA V200 amp
Sep 2, 2012 at 3:18 PM Post #1,741 of 3,079
Hi,
On the V800 the lowest is +6dB, on the V200 it's -6dB.
Correct me if I'm wrong, but at the back of v800, there are no switches that allow me to play with the gain, which means I have to open the unit up?
If so, are there any threads or user who have (reported back with results, and can help me out) opened the v800 before?  Are there any precautions I should take, similar to the post made by Fried about opening up the v200 and setting it to DC? http://www.head-fi.org/t/551173/review-violectric-hpa-v200-amp/1200#post_8299108
Sep 2, 2012 at 4:53 PM Post #1,742 of 3,079
Hi,
That's right, there are no external dip switches. The dip switches are internal and are just like on the V200. I have opened my V800 a few times and it's quite easy.
Also don't set the amp to DC operation as that can potentially damage your headphones.
Sep 12, 2012 at 3:21 AM Post #1,743 of 3,079
Head-fi newbie here. Just got a V200 for my HD800. It's from the US, I mod its AC input from 110v to 230v (I'm in Singapore btw), tested it out w/ the HUD-MX1 as DAC here in office, the sound is so musical even from my Sony EX300 (bundled earphones w/ my A864), a big step up from the HUD-MX1 amp I'd say.
Can't wait to go home and try it out w/ a better DAC and my beloved HD800 :)
Sep 12, 2012 at 12:12 PM Post #1,745 of 3,079
I do like the V200 with the HD800 and it is a good match. Sometimes I want a more neutral amp with the HD800 however so it is just a matter of taste.
Sep 12, 2012 at 10:02 PM Post #1,746 of 3,079
Hooked up my newly bought V200 w/ M1 DAC. Wow! My HD800 never sounded so good before.
Now I can enjoy my musics even better :)
Sep 15, 2012 at 6:04 PM Post #1,747 of 3,079
Has anyone compared the v200 with the Graham Slee Ultra Linear?
I'm looking for an amp that can be used with my T1s and my Edition 8s. I've read at least one review on here that suggests the v200 and edition 8 aren't a good match. Is anybody currently using this combo?
Sep 15, 2012 at 9:46 PM Post #1,748 of 3,079
That is the combo i use and i like it.
I have a Lisa lll, Zana Deux, v200 and Headamp Pico.  I use it with all except the Zana Deux due to impedance is wrong for that amp.  The v200 is the best of the others but Pico is mobile amp and Lisa lll could be considered a home amp with its external power supply but technically is transportable.
Sep 15, 2012 at 9:54 PM Post #1,749 of 3,079
That is an encouraging response. I owned a Triad Audio L3 and regret selling it. If the v200 works better with the Edition 8 than the L3, I'd be very happy.
Sep 16, 2012 at 9:33 PM Post #1,750 of 3,079
I didn't want to create a new thread but it kinda is related to the V200 or at least my use of it. I know I can use rca splitters from the rca of my dac to two headphone amps but I was wondering if I could do the opposite. If I had two dacs would I be able to do something similar to the amp to compare the sound using the rca splitter or would that involve buying an input switch?
Sep 18, 2012 at 12:00 AM Post #1,751 of 3,079
I noticed that my v200+v800 and squeezebox (volume max) runs really really loud.  i have my volume for the v800 at a little less than halfway, and same with v200 as well.
Regarding the gain settings at the back of v200...to turn things down a notch would i go for the - or the + switches?
Also, can you flip both the 6 and the 12 to make a combined 18db?
Sep 18, 2012 at 12:22 PM Post #1,752 of 3,079
rawrster...  Nope, you cannot "Y" together two sources. The output drivers of the two sources will fight with each other. Don't even try it. Your best option for listening to the differences between your two sources is to simply flip the same interconnect cable back and forth. And besides, you don't really want to insert some cheap "Y" connector into the signal path anyway.
Sep 18, 2012 at 1:03 PM Post #1,753 of 3,079
I would recommend that you decrease the gain of the V800. It is almost 4V by default. I adjusted it down to 1.5V.
Sep 18, 2012 at 1:36 PM Post #1,754 of 3,079
I figured that was the case but wanted to be sure. Thanks
