project86
- Feb 21, 2007
Well that would depend on them agreeing with your point of view. If they don't find any convincing technical reason to do so, then they shouldn't build such a device. Or if they do build it despite not really thinking it works, then they would be dishonest.
I think designers and companies should stick with areas that they know about and care about. Don't just do a tube amp because tube amps are hot sellers. Don't just do a headphone amp because those are hot right now (ahem - Cary Audio), don't make aftermarket cables because the margins can be high.... you get my point.
I think it will be a good idea for violectric to sell an audiophile power conditioner box with an ultra clean sine output inaudible noise and the same form factor as the vxxxx line for all those persons that believe that ac current quality is a must for the quality of audio
