boodi
- Nov 19, 2001
so any more experience with the travagan and op amp rolling
Originally Posted by HeadphoneAddict /img/forum/go_quote.gif When paired with my Super Pro DAC 707 from Super Pro DAC707 I find the Red can beat the White and Green, so you might consider that DAC paired with the Red. It was only $110 + shipping, runs on 12-24v but comes with a 24v power brick (so it puts off a little heat), and in addition to the USB it has optical and coax inputs. It uses the same DAC chips as the Headroom Micro DAC and iBasso D1, with LT1364 in the outputs. The Super Pro DAC 707 RCA out can go right into the Red's RCA inputs with any standard interconnect whether $10 or $100. That would be my recommendation. Either that or the Blue Circle Thingee as DAC feeding the Red. |
any thoughts on the Super Pro vs the FubarII, if you've used it? |
Originally Posted by rds /img/forum/go_quote.gif I don't have experience with the FubarII, but I can tell you that the cs4398 (DAC chip) in the 707 Super Pro is very poorly implemented. It is not comparable to the headroom DAC, and if your budget is ~$100 I would recommend an Alien DAC with good output caps. Just my 2 cents of course. |
Originally Posted by URZS /img/forum/go_quote.gif I really don't feel that the white is doing many good things for my k271's. Is one of these worth getting? or should i be trying something completely different. also does "usb speakers" imply that information will be sent to the device to be processed or does it still go through my computers dac. |
Originally Posted by Eldo /img/forum/go_quote.gif Hmm, so I set the configuration of the OPAs to the same as the picture on the first page and no luck. Then I put the original op-amp back in and it is not working. If I turn the volume up to at least 3 or higher, I can faintly hear tiny bits of what is playing, but it is very quiet and static. So......what does it sound like I have done here? |
Originally Posted by HeadphoneAddict /img/forum/go_quote.gif Hmmm... I am not sure how to help you out via long distance. Can you post a photo of how you have the opamps installed? Are you sure you have the pin #1 of the opamp (or adapter) oriented correctly? If the opamps really are installed right - Did a pin get bent under the opamp and not make it into the socket? Is it possible you shorted an opamp and fried the opamp (usually that will happen before it hurts the PCB)? Could there be a tiny brass sleeve missing in one of the holes in the opamp socket on the main board, so that it is making poor contact with the opamp (I had this happen in my iBasso D1, and I stuck some conductive wire inside the hole to let it make better contact with the legs of the opamp)? |
Originally Posted by Eldo /img/forum/go_quote.gif Thanks for the reply. My camera doesn't do close ups very well, but I now have the original op-amp configured just like the photo at the travagans shop here: http://shop.travagans.com/upload/sys...184E63A%7D.jpg As far as the opamps getting fried, if I put them in the wrong way, with the notch facing the wrong direction (so pin 1 and 5 swapped positions), would that fry them? Maybe that is what happened. How do you go about handling opamps typically? Before I started I grounded myself by touching my metal PC case, is it ok to then touch the pins and the top of the opamp? I am pretty sure the 8 pins are in the sockets securely. And from what I could tell, everything was fine with the brass sleeves, however, I will pull the whole PCB out and double check if it isn't a fried opamp. |
