heishiro
- Dec 22, 2009
I am recklessly close to blowing a little money on these, but the bright treble gives me pause, and the filter mod would probably have to be done. For the filter mod, rather than performing surgery inside the earpieces (not in my skill set...), would it not be equivalent to put the RLC components in a little project box, or perhaps the body of a large plug, which the headphones plug into? In other words, do the new components have to be next to the driver, or can they be 6 feet away on the other end of the cable? Thanks for any insights...
Nice, where did you get the ear pads from?
Another pad choice for the superluxes - http://www.amazon.com/Sound-Blaster-Warcraft-Headset-Cushions/dp/B004N8J64Q/ref=sr_1_1?ie=UTF8&s=electronics&qid=1306576990&sr=8-1
... dont affect sound much either.
what does that mean? as in. what are it's effects?
looks like a simple sock mod to me
Well i post another cheap, good and easy-to-do mod for this amazing cans:
Would you ask: "What the hell it's that over the driver??"
Guess it !!!
The bright on higs frequencys will disapear most of it and becames more natural, because mids came forward.
Guess it !!!
