[REVIEW] Sony MH1 – The Best Kept Secret
Jan 25, 2014 at 12:42 PM Post #2,866 of 3,824
Hi, I have an error with your link but I paid €8 for a pair on Amazon and they were original. :)
Great. I just wonder how to pop them open to get at the solder points ...and if it looks OK to get in at, then this is an amazing deal even with a re-cable. :ksc75smile:
Getting to the driver terminals is not easy.
Jan 25, 2014 at 6:29 PM Post #2,867 of 3,824
That is the understatement of the century.
Has anyone discovered an efficient (and non destructive ) method of removing the hot glue from the rear of the driver?
Jan 28, 2014 at 12:19 AM Post #2,869 of 3,824
This seller below seems to say they work with any standard 3.5" player socket ?
I guess their Sony Mh-1BL is just a reference to the color (black) ?
QUOTE " Description
Works with all models of Sony Ericsson and MP3/MP4 Players and any latest mobile phone that support 3.5mm Jack Plug."
http://www.ebay.co.uk/itm/360831700210?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
I thought Sony MH-1 must get a re-cable or an adapter plug to bridge their TRRS plug to anything other than a phone plug hole?
Was going to use it with a Clip Zip if possible.
Jan 28, 2014 at 7:47 AM Post #2,870 of 3,824
QUOTE " Description
MH1-BL is the black version of the MH1 (non-C version).
It won't work with CITA phones. Clip Zip is iffy. You should probably order one of those adapters in case.
Jan 28, 2014 at 10:40 AM Post #2,873 of 3,824
Received my MH1 today from eBay for dinner money. With a zip-tie over the middle button it works fine with the standard headphone jack on my Fiio E5 as well as straight into my Galaxy Nexus handset.
Enjoying some contemporary orchestral music right now: http://www.youtube.com/watch?v=ini5ScescX0
EDIT:This tames the bass nicely:
Jan 28, 2014 at 11:13 PM Post #2,874 of 3,824
Clip zip is a no with the mh1. Unless modded or with an adapter..
Jan 29, 2014 at 2:29 PM Post #2,875 of 3,824
Have a problem with loudness on my mh1. My right phone started to sound much quieter. Tried to clean the filter, but only way to make it much loudier(but after that loss of bass and loudier then left phone)  to remove mesh. Is there any advice how to clean the mesh or to make a mesh replacment?
Feb 2, 2014 at 4:39 AM Post #2,876 of 3,824
My ghetto zip tie method finally gave way and the button is all messed up.
Now there are sellers selling the mh1 with the CITA adapter for $15 together: http://www.ebay.ca/itm/Headset-MH1-EC250-adaptor-For-Sony-Lt26i-st26i-LT39i-C6603-LT36i-st27i-Z1-Black-/310844630845?pt=Bluetooth_Wireless_Products&hash=item485fc8a73d&_uhb=1
Does anyone know of where I can just get the adapter for cheap? The cheapest I found was $6 on ebay and i may as well just buy the headphone + adapter for $8 more.
Feb 2, 2014 at 1:41 PM Post #2,877 of 3,824
Have you ever soldered?  It's very easy to bridge the ground and mic, which is essentially what you were doing with your zip tie method:
http://handtokey.blogspot.com/2013/11/converting-omtp-headphone-to-standard.html
The adapter that comes with those earphones is junk.  They fail very quickly.  It may seem like more, because the earphones are so cheap, but don't think of the adapter in comparison to the earphones.  The earphones are awesome, so they're worth more right?  So $10 or so for an adapter is still very cheap overall for awesome earphones.  Either that or solder them yourself. Both are cheap and easy. :p
Feb 2, 2014 at 4:53 PM Post #2,878 of 3,824
I'm a noob at soldering but I have done it a few times before (and have all the tools!) so I think I will go that route. These are my gym phones so I don't care too much, but I saw your recable and I must say it looks awesome!
Feb 2, 2014 at 5:00 PM Post #2,879 of 3,824
It's pretty simple. Melt some solder on the tip of the soldering iron first. Enough to cover it but not make a big hanging blob. Then touch it to one point (mic or ground) and get the solder hot enough to start flowing and then add more solder to that point and drag it across to the other point and let it cool. Done. I would use heatshrink on the controls after if you want it to look nicer possibly. I just used electrical tape :p
Feb 2, 2014 at 8:25 PM Post #2,880 of 3,824
Already done :D Thanks for the tips, I forgot about the heatshrink until everything was all done. It was really easy (except for my super thick 1.6mm solder.. and 20w iron) and everything snapped back together cleanly. Just curious about the adapters, do they enable the mic and/or buttons? As good as these sound I can't really get myself to buy another pair due to the horrendous cable. Maybe when these ones break I'll try recabling them.
