kookoo
- Jul 17, 2012
Join the club, The MH1c as nice as it is, is somewhat hard to get a good seal from. The best I could manage is to make sure that there is enough slack on the right hand earphone so it doesn't pull on the rest of the earphone.
other people have suggested to wear them over the ear which is a little uncomfortable since it's a flat cable. If you're into DIY then try replacing the Jcord to a simpler Y junction
Quick Q: I'm new to IEM's and while I enjoy the sound from the MH1's I'm really having a hard time getting a reliable seal/fit with the tips. The large ones fit the best and don't pop out but I lose some of the bass with these. The Medium tips seem to seal well but fairly easily come out while walking or some moving. If the cable isn't in just the right place the left earpiece pops out by itself. The small tips seem to seal well enough but I can always 'feel' them almost pushing in my ear canal. They're not hurting and I've not pushed them in too far but I'm just very aware they're there. They seal but don't feel 'comfortable'.
I'm wearing the earphones in the intended position with the right hand earphone around the back of my neck and with them down, not over the ears.
How do I find a reliable fit that keeps the seal well during movement/exercise with these tips?
