NZtechfreak
- Jan 19, 2012
Same thing.
That will work perfectly.
You don't need an SD card to update the firmware. It has internal storage. Just put the firmware on that.
Of course, you will want the SD card, because 32GB is not very much for lossless files.![]()
After a months use and seven charges the max battery time (no display random play) I can achieve is under 8 hrs, could my battery be sub standard? I am also wondering if there is a sonic break in with the player, does it improve over a hundred or so music hours?
Everything I've read says it will only look for the update file in the extra slot 1.
Have you updated your device from the built in drive? If it's trying to update itself from the drive it's updating seems to me that could brick the device.
If that's true. I apologize for supplying bad information.
I don't own the device, my reply was based off what I believed I knew about it. I'm very skeptical about this. It does not make sense that the QuestStyle would require external memory to update. That sounds absolutely backwards to me.
QPR1 doesn't have wifi so using the micro sd card is sound method.
Wasnt the update the same on X5...External slot?
Is it? Why?
Sorry someone who posts wrong advice doesn't merit a reply.
If you can put music on the internal storage, without wifi, why can't you put firmware update files?
As opposed to it's internal storage?![]()
I suspect that might have something to do with how hard you're driving it. Do you listen loud, do you have inefficient cans?
