JerryLeeds
- Jun 12, 2015
I'm ordering an SD card to update my firmware.
Is this the correct format card?
http://www.amazon.com/SanDisk-microSDXC-Standard-Packaging-SDSQUNC-128G-GN6MA/dp/B010Q57S62/ref=sr_1_1?ie=UTF8&qid=1448134134&sr=8-1&keywords=sandisk+128gb+micro+sd+card
The manual says it takes a 'Micro SD' this is a 'Micro SDXC' - same thing?
Thanks for any info/suggestions.
Yes ... It's the correct type ... Firmware doesn't need 128gb so you can get by with a smaller cheaper cadd
