jacdan
- Feb 14, 2004
I'm using 32 ohm Grado RS1s and SR225s with the MKV and hear absolutely no hiss, for those interested.
Originally Posted by jacdan /img/forum/go_quote.gif I'm using 32 ohm Grado RS1s and SR225s with the MKV and hear absolutely no hiss, for those interested. |
Originally Posted by Penchum /img/forum/go_quote.gif I'm not sure what ohms rating your Grado's have, but if it is at or under 32 ohms, you might want to do one of two things. One, would be to purchase impedance adapters, to raise the ohms total up to/above 128 ohms (with MKV) or find another amp that is built specifically for handling lower impedances. Many SS headphone amps of quality, that are built to handle ohms as high as 600 ohms, will show hiss and/or grounding noise at impedances below 32 ohms. It's not a measure of their quality, it is a characteristic of their design. If you could hear one of these amps with a pair of 250 or 300 ohm headphones, it would put things into perspective very quickly. ![]() |
Originally Posted by justadollar66 /img/forum/go_quote.gif - However, there's obviously a grounding issue because when I put electrical tape on the Little Dot's ground the issue disppears even with the Paradisea+. In the end when it works.... it sounds great! |
Originally Posted by justadollar66 /img/forum/go_quote.gif Thanks. I'm running my Denon AH-2000 through a Little Dot MKV and at 25 ohm this might explain the hiss hum issue I'm getting. On an interesting note" - I don't get the problem when I run my Creative Zen as my source. - When I run my Laptop through my Paradisea+ as the source the issue kicks in big time. - However, there's obviously a grounding issue because when I put electrical tape on the Little Dot's ground the issue disppears even with the Paradisea+. In the end when it works.... it sounds great! |
